drpapillon's avatar
drpapillon
Follower
Jan 08, 2018
Set-Up PLP1200 with existing PL1200
I have a PL1200 that works great.  However I need one more adaptor for another device.  So I purchased a PLP1200 which comes with two units (I think they are called adaptors). Before setting them up ...
  • michaelkenward's avatar
    Jan 09, 2018
    drpapillon wrote:
    They said to just plug one of the PLP1200 units in an outlet and keep the old existing PL1200 connected to the router via ethernet cable.
    That's wrong. Here's what you have to do.
    >>> Adding a powerline adapter to an existing powerline network <<<
    There is a manual for the device somewhere at the end of this link:
    >>>> PLW1010v2 | Product | Support | NETGEAR <<<<
    See page 19.
    It is often easier to set up the new plug in the same room as the "host" plug that is attached to the router. After you have set it up you an move the new plug to its final destination. It will remember its settings.
