vmi9d3
Mar 28, 2016Follower
set up questions
A couple of questions I hope somebody can point me in the right direction to figure out: 1. Will XET1001 work with the XWNB5221 (comes with XWN5021and XAV5221) and are there any limitations to speed...
ElaineM
May 11, 2016NETGEAR Employee Retired
Hello vmi9d3
You may want to see this link for more information about the compatibility questions you have.
Regarding the password, can you provide more information about your network setup?
What is the router model number do you have? How are things connected? If you have used the WPS PIN method to connect or setup the powerlines, you may have to get the wireless password from the router. Anyhow, let us know more information about your network setup to guide you better in setting this powerlines.
