Gear1011
May 23, 2018Aspirant
Setup Netgear PLW1010 WITHOUT WPS Button
My router does NOT have a WPS button and I bought two PLW1010 kits. Right now my WIF search shows two different WIFI systems and my WIFI calling drops when I go to the other room.
I plugged the unit without the antenna to the wall next to my router and got all of the green LEDs and I plugged in the CAT5 cable to the back of my router. My other units are scattered about the house.
How do I integrate ALL FOUR units to my WIFI system so that I essentially have ONE WIFI system and I can walk around the house using WIFI calling and not have my calls drop.
THANKS!!!
- Gear1011Aspirant
Netgear,
Is there someone in your tech support who can answer this question???
How are these set up? Do you have two separate Powerline networks? Or do they all feed back to one plug connected to the router?
Support here:
>>> PLW1010 | Product | Support | NETGEAR <<<
Follow the setup instructions there.
This explains how to add new plugs to a network. But so does this:
>>> Adding a powerline adapter to an existing powerline network <<<
There is a Powerline User Manual somewhere at the end of this link:
>>>> PLW1010v2 | Product | Support | NETGEAR <<<<
That explains how to set the wifi to the same SSID, although this may not be the best way to run things.
I am surprised that your router does not have a WPS button. What make and model. is it?
- Gear1011Aspirant
Thank you Michael for being willing to help!!!
Right now I have the Netgear Powerline "base unit" (I do not know what this thing is called) that is connected to the singuliar router/WIFI base station located in the kitchen. In one bedroom I have the Netgear Powerline WIFI unit (I do not know what this is called) located in the bedroom.
My router/WIFI base station is a DuraSpeed C428.
I want to add a second and third WIFI unit in two other rooms.
Can you please tell me what units I need to buy to make this happen.
I bought TWO WPL1010 packages however each package has a base unit and a WIFI unit so that does not seem correct because one base unit will be wasted.
THANKS
Gear1011 wrote:
I bought TWO WPL1010 packages however each package has a base unit and a WIFI unit so that does not seem correct because one base unit will be wasted.My first move would be to introduce the second wifi plug to the one that is connected to the router.
Here's how to do that:
You can set up the new plug near to the router plug, then when you know it works move it to where you need it.
You can take the second (no wifi) plug through the same process and put it where it is useful. Maybe you have a smart TV or something that you now connect with wifi, but that also has a wired LAN socket. Get it to work and it will be more reliable than wifi.
