Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
xylem
Sep 15, 2008Aspirant
"Reset the Powerline adapters to the default settings using the utility."
This is a rather useless piece of advice:
what "utility" and where is it hidden?
can any one help?
thanks
om
hummmmm How can we say that the advice is useless if you yourself does know anything about the utility.... be considerate to others.. :) try to research before saying something you are not "knowledgeable" of....
VE6CGX
Jun 11, 2016Master
So what is new? If one is trying to do something (s)he does not understand fully to begin with result is unknown.
