Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
PetrolDave
Mar 31, 2008Tutor
omuise wrote: "Reset the Powerline adapters to the default settings using the utility."
This is a rather useless piece of advice:
what "utility" and where is it hidden?
Look on the CD that came with your Powerline adapter, on there you will find a program that allows you to set the encryption - this is the "utility".
Better than the CD though is to download the latest version from the Netgear website. BTW whatever Netgear Powerline product you are using if you are running Vista you need version v1.0.1.0 or later (you'll find that under XEPS103).
