Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
8uLiebr
Apr 05, 2009Aspirant
Orbital:
Toward the end of your message at the beginning of this thread you state
Here's my story:
I have been using my two NETGEAR XE104 adapters successfully by themselves for several months until AT&T U-verse was installed recently. AT&T provided 2 Asoka PlugLink 9650 adapters as part of their solution and the XE104s were disconnected when the Asokas were installed.
Based on statements I have seen from homeplug.org it seems I should be able to expand my powerline network by using my XE104s together with the Asoka units. The XE104s work fine by themselves and the Asokas do too. But so far when I try to use them at the same time they are unable to see each other. I don't think I am trying to use any "advanced features". I just want all the devices to recognize each other and talk nicely.
Is there a solution or am I out of luck?
8uLiebr
Orbital wrote: Troubleshooting NETGEAR's Powerline Products
... In particular, remote and advanced features may not work between Powerline manufacturers.
Here's my story:
8uLiebr
