Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
BobKarolak
Dec 15, 2009Aspirant
I was also told by support that the XAV101's will not work across different breakers in my home. If that's true, they are unusable for the situation I have. Our house has been completely rewired in recent years, including a new breaker box. I would have to use the XAV101's in the same or immediately adjacent rooms to be on the same breaker. If that's the case, I can run CAT5 cable. I wanted to connect equipment at different ends of the house and avoid running 70+ feet of cable.
NetGear - is this true about different breakers????
