Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
trodder
Oct 18, 2010Aspirant
fordem wrote: As a general rule - they do.
However - depending on the wiring in your home, and maybe those of your neighbours - yours might not.
Question - what do you mean by "on one node of the breaker"?
By the way - I saw your other post - have you had some sort on power quality survey done to know that noise is the cause of your problem or are you just jumping to that conclusion?
what does that mean depending on the wiring in your home? It should be a simple they will or they won't. All homes should be wired the "same way" the will simply have different combination of rooms or whatever on each circuit.
