Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
dzjepp
Dec 01, 2010Novice
Hello,
First I apologize if this has been asked before. I recently purchased the XAVB2001-100NAS bundle from Amazon (comes with 2 XAV2001 adapters). I plugged one upstairs (one story home) into the AT&T router that comes with Uverse. The other adapter I plugged in the basement to use with the Roku box, it's not plugged into a power strip. It worked flawlessly for about 2 days. Now one of the adapters (the one plugged into the Roku) goes into sleep mode. Even though the ethernet is plugged in and I am using it online.
I tried changing the adapters and still the same thing happened. One seems to turn off completely. I have read about the documented "sleep mode" that shuts the adapter down when there is no ethernet activity. But this should not be happening since I am trying to stream stuff on Roku, and it just shuts down.
Perhaps I have faulty adapters? Can I return them to netgear for a replacement?
Thank you for your help
