Orbital
Dec 12, 2007Aspirant
Troubleshooting NETGEAR's Powerline Products
Powerline products work better when plugged into the wall without power strips, extension cords, surge protectors, or interruptible power supplies.
beerocrat
Sep 07, 2015Aspirant
I recommend taking it back and getting your money if you can. That's the best way to avoid the inevitable migraine that this product will undoubtedly cause you. I have a three year old home that has had zero electrical problems in 110 degree heat for an entire month. As soon as I had the pl1200 up and running, it started tripping breakers the instant I started pushing data across the network. It only took me about 30 minutes and 8 tripped breakers in three different rooms before I found this forum. This product will likely cause issues for anyone that users it.
- michaelkenwardSep 12, 2015Guru - Experienced User
beerocrat wrote:
This product will likely cause issues for anyone that users it.No problems here. So can't be "anyone".
It sounds like you have a sensitive system. Have you tried different powerline kit? If it does the same thing, then you have a different issue.
Rather than rejecting the hardware, which works fine for many people, I'd dig a bit deeper. Have you had an electrician check the earth system on your wiring? The plugs may be revealing a more worrying underlying issue.
