solidsolutions
Feb 01, 2021Aspirant
Two networks both using PLW1010 V2 for the headend - problems?
I have two completely different networks headended by two routers connected to a single Arris cable modem for our two building residential property. One network already has a PLW1010-100NAS with two...
michaelkenward
Feb 02, 2021Guru - Experienced User
Not sure that I follow the layout here:
solidsolutions wrote:
I now want to add another PLW1010 headend with a single wireless remote to provide both a wired ethernet connection for a small switch and better wireless connectivity.
Is this new Powerline network supposed to be independent of the existing network?
Is it using the second router as the "host"?
solidsolutions
Feb 03, 2021Aspirant
I have two distinct networks each with their own headend router, IP structure, SSID, etc. The "B" network has one headend PL1010V2 and two remote PLWs - one in each structure. Each of these has a switch connected to the ethernet port on each of the PLWs to provide wired connections. The PLWs also use the same SSID as the headend router to allow for seamless WiFi for ourselves and visitors. This works really well and provides good performance.
Right now I'm using a very old WiFi extender for the "M" network but it continues to have issues some of which I assume are due to the concrete block walls I am also concerned as the DD-WRT version is ancient and I'm sure it has major security holes. With Kali I can crack it in just a few minutes.
I believe that I should be easily able to add a completely separate headend/remote pair based on my research - I just want someone who has actually done this. I do understand my network is more like a business would have but that's what I did my entire life until retirement.
