ChickenStrips's avatar
Apr 27, 2019
Unidentified Network PL1200
I've setup the the powerline how the instructions told me to but checking my desktop it reads the message. "Unidentified Network, No Internet" Under the Ethernet settings. All three lights on the device glow but the third light turns off after about 10 minutes of no connection. Solutions?
  • michaelkenward's avatar
    michaelkenward
    That sounds like a Windows message.
    My first guess is that you need to tell Windows that you are on a "private network".
    • Network and Internet settings
    • Network Status
    • Change Connection Properties
    • Network Profile
    • Private
    • ChickenStrips's avatar
      ChickenStrips
      My Ethernet does show up as Public but the method to change it to Private you showed in the previous reply isn't working. I followed all the way up "Network Status" and once I click on "Change Connection Properties" It just brings me to the Unidentified network under the ethernet connection with no option to change the network from public to private. I clicked on "Troubleshooting" in the "Network Status" window and it came up with the problem. "Ethernet" doesn't have a valid IP Configuration" Not fixed.
        michaelkenward
        Only you know how your PC is set up and which version of Windows you use. There are several ways to get into the network settings.
        Here is another way in, from the notification area, right click the Internet/Network icon and go to Open Network & Internet settings.
        Windows Network Status
        Click the Ethernet icon and then change the Network profile.
        I assume that your Ethernet works as expected on the local network. If not, you may have to fix that first. For example, you may have to check the drivers for your PC's Ethernet.
