RobinWorlidge
Nov 13, 2016Aspirant
Using Powerline 1200 and virgin media broadband. Keep getting speed reductions
Get good speed of 100+ mbps, but it does drop to less than 50 a lot of the time. If I switch of the powerline 1200 connected to the router, and switch it back on again, I instantly go back up to 100+...
michaelkenward
Dec 09, 2016Guru - Experienced User
Register now and use the RMA process.
If you are in the UK, then Netgear's pathetic support conditions do not apply. You should expect at least a year's life out of these devices.
But I would also investigate what is happening at the router/modem end. May something there is throttling your powerline devices.
Oh, and do you notice any problems at this slower speed? Or are you just being a slave to the speedtester?
RobinWorlidge
Dec 11, 2016Aspirant
Did not really notice any major problems with the speed reduction, so reckon I can live with it. Just seems odd that even when the speed through the powerline drops below 50 mbps, through wifi on my phone it is usually over 80
