citizenAndSaint
Mar 04, 2018Aspirant
Using Powerline 1200 with 6-Outlet Tap, Grounded
Hello, will using a GE grounded 6-Outlet Tap for plugging one of my Powerline 1200 adapters into degrade the performance or should I be okay? The only other thing I plan to plug in to the 6-outlet tap...
- Mar 05, 2018
It should work fine. It does here.
citizenAndSaint
Mar 05, 2018Aspirant
Thanks for the feedback. The outlet tap simply adds more outlet plugs to a standard 2 plug outlet. It doesn’t do anything special otherwise.
michaelkenward
Mar 05, 2018Guru - Experienced User
- citizenAndSaintMar 05, 2018Aspirant
Great. Thanks. I'll give it a shot and report back if that works as a solution.
- citizenAndSaintMar 07, 2018AspirantThanks for the help. The outlet tap works well.
