joannefbrown's avatar
joannefbrown
Follower
Sep 21, 2017
We cant get our wireless extender to connect to the network
Hi, we have a plw 1000 which is running our 1200 adapter fine but we cannot get the 1000 Wi-Fi extender to work, it just comes up with authentication error when trying to log on. we have tried the fac...
  • michaelkenward's avatar
    Sep 22, 2017
    Can you explain what that bit means?
    The PLW1000 comes in a bundle with the PL1000.
    What is this 1200 adapter?
    Your "signature" says that you have the PL1200.
    Are you trying to combine a set of PL1200, PLP, 1200, PL1000 and PLW1000 plugs?
    If so, did you read this?
    >>> Adding a powerline adapter to an existing powerline network <<<
