mrcjr24's avatar
mrcjr24
Follower
Dec 03, 2017
Weak Wifi Signal
I just purchased a Powerline 1000 for my 2100 sq ft home. It's an old Victorian so the walls are plaster and therefore very thick. All 3 of the green lights are active on my Powerline Adapters, but t...
  • michaelkenward's avatar
    Dec 04, 2017
    The PL1000 on its own will do nothing for your wifi. It is an Ethernet plug. The PLW1000 does wifi.
    A Powerline wifi access point has a limited range, like all access points. You may need several strategically placed around the house.
