Beep
Oct 31, 2015Aspirant
WGX102 and XE102 not connecting
I have the WGX102 and XE102 and have worked brilliantly up until now. Suddenly I cannot connect to them. Have reset everything green lights on everything but no Wifi. Please help
Beep
Nov 01, 2015Aspirant
I seem to have a bit of an answer, if I change the socket that its in it works. It has worked fine on the socket it was in for years now its suddenly stopped. How do I get it to work in the old socket again?
JamesGL
Nov 06, 2015NETGEAR Employee Retired
Hi Beep,
If it works with other socket then it might be a problem with the distance from one the 1st adapter to the 2nd adapter that is why the old socket will no longer work.
JamesGL
Community Team
- BeepNov 10, 2015Aspirant
Does the distance degrade over time then because it used to work and now doesnt.
I have replaced it now with the latest powerline product.
