Beep
Oct 31, 2015Aspirant
WGX102 and XE102 not connecting
I have the WGX102 and XE102 and have worked brilliantly up until now. Suddenly I cannot connect to them. Have reset everything green lights on everything but no Wifi. Please help
JamesGL
Nov 06, 2015NETGEAR Employee Retired
Hi Beep,
If it works with other socket then it might be a problem with the distance from one the 1st adapter to the 2nd adapter that is why the old socket will no longer work.
JamesGL
Community Team
Beep
Nov 10, 2015Aspirant
Does the distance degrade over time then because it used to work and now doesnt.
I have replaced it now with the latest powerline product.
