DonaldLaborde
Jan 08, 2016Guide
What kind of CPL/Wifi model is compatible with CPL 500 (XAVB5401) ?
Hi everyone, I bought the pack of 2 adapters CPL 500 (model XAVB5401) with outlet and it works very well! Now I need an additional adapter to extend the wifi in the garage of my house. I would li...
clithes
Jan 09, 2016Prodigy
Your current kit is HomeplugAV compliant. So any model that is HomeplugAV or HomeplugAV2 compliant (as these are backwards compatible) will work with the XAVB5401's
Hope this helps
DonaldLaborde
Apr 22, 2016Guide
Hi Clithes and thanks for your answer.
I have a network with 2 CPL 500 (XAVB5401) adapters.
Then I bought the wi-fi CPL 500 XWNB5201 (XWN 5001 and XAV5201).
When I connect the XWNB5201 the XAVB5401 stop running. What can I do to make both running please ?
Thanks in advance for helping me.
Best regards
- JamesGLApr 28, 2016NETGEAR Employee Retired
Hi DonaldLaborde,
Try to reset all the adapters and reconfigure them.
- JamesGLMay 01, 2016NETGEAR Employee Retired
Hi DonaldLaborde,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
