webakerjr's avatar
webakerjr
Follower
Jun 06, 2021
WIFI SECURITY FOR AC1000 MODEL R6080
My Norton virus protection says I should update my WiFi security to WPA2/WPA3 Personal (AES).  I have the latest firmware update.  I don't find this level of security in the router setup.  Is there a way to upgrade it?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    It is probably just trying to scare you with warnings of a newish security protocol, WPA3, that has yet to reach most devices. If you have not already implemented WPA2, then your router already supports it.
    But the R6080 is pretty well the bottom of the range Netgear router. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX. Nothing wrong with it being slow, just don't expect too much.
    You have posted your message in the section of this community given over to Home WiFi Adapters and Powerline. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but Powerline is nothing like a router so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    General WiFi Routers (Non-Nighthawk) - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
