cleo2612
Mar 29, 2015Novice
WN3500RO continual loss of connectivity after 2/3 days
I have a MacPro with the latest OS 10.7.5 ad my MacPro loses connectivity to Netgear extender which can only be fixed by turning off the extender for 10 sec and restarting it. It is annoying and time...
SamirD
Apr 06, 2015Prodigy
I should have been more clear. :o
cleo2612 wrote: Thank you for your suggestion :): It does have a power saving feature in as much as it goes to screen saver then the screen goes to sleep. The option to put the hard disc to sleep where possible is not turned on.
The loss of connectivity can occur whiles I am working on the computer. It does vary though, sometimes it can go fo days and days and sometimes it loses it each day.
The powerline adapters have a sleep mode that they sometimes do not wake up from. But if your computer is sleeping, the powerline is probably doing the same.
