cleo2612
Mar 29, 2015Novice
WN3500RO continual loss of connectivity after 2/3 days
I have a MacPro with the latest OS 10.7.5 ad my MacPro loses connectivity to Netgear extender which can only be fixed by turning off the extender for 10 sec and restarting it. It is annoying and time...
SamirD
Apr 06, 2015Prodigy
There was supposed to be a way to disable the sleep mode on the powerline, but I don't know where the instructions for this might be. With you using the computer on and off, it may be going to sleep.
cleo2612 wrote: Thank you so what is the fix? BTW I do use the computer off and on during the day and evening.
As a test, run 'ping -t 8.8.8.8' in a command prompt and see if the problem goes away. If it does, then it's definitely a sleep mode issue on the powerline.
