Ian8
Jul 27, 2016Aspirant
X10 home automation interference with NETGEAR PLW1000-100UKS
Will Netgear PLW100-100UKS interfer with powerline signals of X10 home automation system and vise versa? Thanks.
JamesGL
Aug 04, 2016NETGEAR Employee Retired
Hi lan8,
May I know what is the exact model number of the X10 home automation system do you have and how does it work so that we can check if the powerline will interfere.
JamesGL
Community Team
- Ian8Aug 08, 2016Aspirant
Dear James,
X10 is a powerline data system used wordwide. Several manufacturers make to this standard for home automation. See Marmitek and Haibrain etc.
See Wikipedia X10 then select X10 (industry standard) for protocols etc.
The model numbers of units I use to transmit data over powerline are CM15pro, TM13U and TIP10RF.
To recieve powerline data I use LD11, AD10, LW12, LM12U and AM12U
To link by radio to CM15pro and TM13U I use HR10, MS13E and SS13.
Regards Ian8
- JamesGLOct 10, 2016NETGEAR Employee Retired
Hi lan8,
There is no interference issues with the X10 home automation devices with the NETGEAR powerline adapter.
JamesGL
Community Team
- JamesGLOct 13, 2016NETGEAR Employee Retired
Hi lan8,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
