whoit's avatar
whoit
Tutor
Feb 29, 2012
XAV5004 doesn't always come out of standby
I've got an XAV5001 connected to my router, another XAV5001 at a PC, and they work together well.
However, I also have an XAV5004 with a DVD player and AppleTV (G1) connected, and it rarely comes out of standby.
Once it's gone into standby, I usually have to disconnect/reconnect the power cable to reboot it and get it to come online.
When it does, I get decent speeds. It doesn't lose it's connection once it's out of standby, and I don't appear to have any wiring issues.
I have the current firmware (it hasn't changed in many months), and I'm getting really frustrated by this. Tech Support is not much help. I returned the first XAV5004 I bought for a replacement thinking it could be the device, but this second one behaves exactly the same.
Does anyone have any suggestions?
Are other people having the same issue?
  • Hi Guys,
    I was having the same problem as everyone else untill I found a solution.
    If i set a security key on both devices by doing the push button on one then the other it works everytime it comes out of sleep.
    When i remove the sec key the problem happens again.
    I suspect that when the devices first see each other they agree on comms right then and there when the 5004 goes to sleep the 5001 forgets the temp key. When the 5004 wakes up it uses the same key as before but the 5001 has forgotten it and blocks traffic.
    Where a key is set and the encryption is on both have the same keys in them no matter what state they go into or out off.
    Not sure if this will work for all but it solved the sleep issue for me.
    Cookie
  • I got the same problem it's very annoying! There is no help from netgear what so ever!! :mad:
  • Sound interesting, so this will stop the unit from going to sleep?:rolleyes:
    Will it has any bad effect to the overall network performance?
