d_rick's avatar
d_rick
Tutor
Dec 21, 2013
XAV5101 - QOS setting to align with rest of network
curious what the optimal QOS setting would be on this side of the network to line up with the rest of the QOS setttings:
these units support VLAN tag and TOS field, i assume i should enable them both to support video streaming?
if so, then how would these settings align against the WMM QOS settings on the R7000 AP, or Video QOS setting on the GS716, and finally QOS packet scheduler / AD Hoc QOS mode / WMM enabled on Windows clients?
not sure if they need to be consistent end to end, but doesn't seem like they are.
1 Reply
  • I don't think VLAN tag would associate with router. You may able to prioritize the LAN ports on router side , switch while you can keep using the QoS separate so that devie behind the power line works within that device
