surfjabroni1
Sep 17, 2016Follower
XAV5421 & XAV5201 powerline devices won't give an IP on electrical outlets in living room only
Hi everyone, I have a XAV5201 cabled into my R7000 router and I have an XAV5421 which will ONLY give an IP adress 169.... in my living room but will work fine giving out my 192.168.0.x addresses in o...
michaelkenward
Sep 18, 2016Guru - Experienced User
First get the two devices talking to each other in the same room, where they should be on the same electricity circuit.
When you have achieved that, move the "remote" plug to the other room. If that doesn't work, your house may have wonky wiring.
I assume that you have read the literature that goes with these devices:
XAVB5421 | Product | Support | NETGEAR
XAV5201 | Product | Support | NETGEAR
