laurentroger
Dec 02, 2015Aspirant
XAV5421 Problem
Hi, I bought several and they XAV5421 It Works fine for a certain time. After a time of a powerline began to no longer function on an IP in particular my LAN. Even after reset nothing works. So I...
- Dec 14, 2015
JamesGL
Dec 02, 2015NETGEAR Employee Retired
Hi laurentroger,
What are the IP addresses that are blocked when using the XAV5421?
Do you get the same IP addresses with the 200 powerline?
laurentroger
Dec 05, 2015Aspirant
Hi,
For example 192.168.1.121 and it is a static ip (no DHCP) so it's the same with 200 powerline.
regards
- JamesGLDec 05, 2015NETGEAR Employee Retired
When no connection with the XAV5421, can you still ping websites or even ping the default gateway?
- laurentrogerDec 07, 2015Aspirant
Hi,
Yes I can go everywhere except on an IP (the one mentioned above)...is what intrigues me the most besides ...
I have the impresion that the quality of electronics the powerline is not great ...
Regards
- JamesGLDec 08, 2015NETGEAR Employee Retired
Hi laurentroger,
That's a bit strange that the adapter blocks certains IP address. It does not have any feature that will block IP address or even MAC address. Have you tried contacting support team?
