TheBeO
Sep 11, 2011Novice
XAV5501 problem after PC standby
Hi,
I've just bought a XAVB5501 pack, with 2x XAV5501. I plugged one near my cablebox, and the other one in my bedroom to a Desktop PC (let give the name PC1, that runs Seven 64x). It works fine, connection is good (Rx and Tx > 100Mbps).
But I have a very bad problem. Every time my PC1 goes to standby, when it wakes up the connection is lost. The XAV5501 always stays in standby mode. So I need to desactivate my network card on PC1 (it is an Intel 82579V Gigabits), wait a little, then reactivate the network card. This way the XAV5501 "see or receive" wakeup event, and the connection is established.
So I know that problem is about standby/wakeup. What I've already done:
-update both XAV5501 firmwares to lastest (v0.2.0.9CE)
-update network card to lastest driver from Intel
-turn off every thing relative to economic mode in my network card (there's a lot of option in network card driver panel page under Seven)
-turn on Wake On Lan/Magic/Link on my network card, but I don't think it could solve anything, because my problem is to wakeup the XAV5501, not my PC
I'm here, and don't know what to do now.
Please can someone give me a solution?
Thank you very much in advance, and I apologize for my bad english.
- PagefaultAspirantHi,
I'm owning 2 pairs of the XAV5004/XAV5001 combo and one pair of XAV5001 set. So at all 6 devices!
On all 3 pairs I have the same standby problems as ZepDad described. I think it happens more frequently when the connection is bad. But the strange is, that a replug is solving the problem within a few seconds.
I also think it doesn't matter which device is unplugged.
I also think that the actual firmware (2.0.9) is buggy. It is a pity, because the connection is very stable.
I also contacted netgear support. But they said the device is defectiv and I should send it back for repair. I really don't believe all devices are broken!
@netgear: If there is no way to fix the problem... give us an option to kill standby mode :D - TransalpAspirant
Pagefault wrote: @netgear: If there is no way to fix the problem... give us an option to kill standby mode :D
That is (or could be) a solution..... or a reboot option after every day at a certain time?
Mine XAVB5004 sometimes has no connection after sleep mode. Letting the device reboot after changing name or whatever in the utility also solves the problem, because I'm able to connect after that.:D - PagefaultAspirant
Transalp wrote: That is (or could be) a solution..... or a reboot option after every day at a certain time?
A daily reboot option doesn't make sense because the device still can be stuck in standby. Better would be a reboot after waking up from standby.
