Ploeggie
Feb 16, 2016Aspirant
XAVB 5601 does not work
Hi, Recenty purchased two used XAVB5601/AV500 powerline. Seller says they work. All lights are burning, No problems from the outside. However...cannot get them to work.. reset them several times, ...
Ploeggie
Feb 17, 2016Aspirant
Hi,
Thx for yr help.
Downloaded the software, did the reset.
got three green lights now, but my PC keeps saying 'no internet' on this connection.
Any other suggestions ?
thx
Sander
clithes
Feb 17, 2016Prodigy
When you run the powerline utility does it find all the adapters ?
For any that it doesn't, connect these to the PC and try to reset again
- PloeggieFeb 17, 2016Aspirant
The software tools only shows the XAVB5601 connected direct to PC.
The other 2 powerlines (XAVB5602) are not visible
