Ploeggie
Feb 16, 2016Aspirant
XAVB 5601 does not work
Hi, Recenty purchased two used XAVB5601/AV500 powerline. Seller says they work. All lights are burning, No problems from the outside. However...cannot get them to work.. reset them several times, ...
clithes
Feb 17, 2016Prodigy
OK try connecting each one of these to your pc and resetting the encryption key to HomeplugAV as well
- PloeggieFeb 17, 2016Aspirant
connected all 4 plugs and did the reset same way on the them..
still no internet/ nothingh
connected the XAVB5602 only and they work, Cannot get these XAVB5601 do to the same, are they broken ?
- clithesFeb 18, 2016Prodigy
When you connect the XAVB5601 units to your PC and run the utility, when you try to factory reset them does it say that they have been reset, or 'Factory Reset failed' ?
