Ploeggie
Feb 16, 2016Aspirant
XAVB 5601 does not work
Hi, Recenty purchased two used XAVB5601/AV500 powerline. Seller says they work. All lights are burning, No problems from the outside. However...cannot get them to work.. reset them several times, ...
Ploeggie
Feb 20, 2016Aspirant
Thx for trying. Don't like to quit
JamesGL
Feb 27, 2016NETGEAR Employee Retired
Hi Ploeggie,
clithes might be correct that the device is faulty. You have tried reset on the device but still no connection but it works with to another powerline adapter. You may try to connect it in just one room where the router is. If still the same then possibly the adapter is faulty.
