Swainez's avatar
Swainez
Follower
Oct 14, 2015
XAVB5421 doesn't work with certain programs
Hi, so i bougth the NetGear XAVB5421 as i get weak wifi signals. It can get on the internet fine, however it doesnt work with Teamspeak or BattleEye. For teamspeak it doeant connect to any server and for battleEye it cant connect to the master server. On wifi i can use these 2 with no problem.
Anyone else ever had this sort of problem?
Thanks
1 Reply
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Swainez,
    Welcome to Community!
    Have you check the connection speed you can get using the powerline adapters compared to wireless? Those softwares or programs might require specific speed which the powerline cannot provide.
    JamesGL
    Community Team
