anap's avatar
anap
Follower
May 03, 2012
XAVN2001 connected to ADB P.DG A4001N
I have a new wifi router from Telefonica ADB P.DG A4001 in my second floor.
I need to extend wifi in the first floor and connect my TV-decod to internet using PLC. I cannot connect PLC directly to the router as I have diferent lines.
I have two questions:
1.- Could I extend wifi connecting A4001 to Netgear XAVN2001?
2.- Could I have the network like this?
Router (wifi) ----> XAVN2001 (PLC) ----XAV2001 ----(TV-Decod)
I have always seen XAV2001 connected to the router and then to XAVn2001, but its imposible to me.
1 Reply
  • if you have powerline link issues, does not matter which adapter you conect to the gateway...
    You can try other solution to connect to TV set as wifi range extender as WN2000RP, WN3000RP, or WN2500RP, which they all have ethernet interface or even use the wifi adapater, you might have to add a dual band router to you gateway and get away from 2.4Ghz interference, and WN2500.
    Router (wifi) --> WNDR3700 (optional) --> WN2500RP -->WNCE3001 -->(TV-Decod)
