donj12's avatar
donj12
Follower
Mar 02, 2018
Xe104 not connecting to internet
Just tried to use my powerline adaptors to connect several devices where I couldn't wire for Ethernet directly... The adaptors were being used to a Sony TV and a Sony soundbase.. Each of the connections had an ip address that was not internal address from my router.. so the ethernet connection was ok on each device, but the internet connection was not
When I had these devices connected via WIFI.. everything worked fine.. any ideas?
Thanks for your time
1 Reply
  • michaelkenward's avatar
    michaelkenward
    The XE104 is first generation powerline. It is 13 years old and does not follow the more recent AV standard.
    How did you have that set up? They are not wifi plugs.
    As you have changed your network, it might be worth setting things up from scratch.
    There is a manual for the XE104 somewhere at the end of this link:
    >>>> XE104 | Product | Support | NETGEAR <<<<
    To be honest, these things are so slow (85Mbps) that it might be easier to buy a pair of "500s", or even the newer faster "1000s", rather than playing around with these. You can even get plugs that come with an integral wifi access point.
