kcp2000
Feb 18, 2015Novice
XWN5001 loses path to router
I have the following set up : Netgear Powerline XAV5201 - Firmware 0.3.0.6CE XWN5001 - Firmware V0.4.0.7CE Netgear D6200 Router - Firmware V1.1.00.14_1.00.14 Every few days or so a situa...
JamesGL
Nov 19, 2015Master
HI Siplax,
Have you checked if the devices connected to XWN5001 can grab valid IP?
How far is the XWN5001 from the 1st powerline?
Have tried moving the XWN5001 closer to the 1st powerline or in just one room?
JamesGL
Community Team
rosmith52
Dec 03, 2015Aspirant
I'm suffering the same issue I'm getting disconnected from the router numberous times through the day. Looking at the router event log I see many (341785.610000) Device disconnected: Hostname: XWN5001 IP.......... in a 20 minute window I've seen 6 only one causing a complete disconnect. I've recently changed ISP to Plusnet Fibre (Hub One) so my router conigurationn has changed but the problem predates the change and is now more frequent. I planned to do some testing by installing an XAVB5221. Then I planned to start swapping routers. But any advice you can give wuld be appreciated
- rosmith52Dec 03, 2015Aspirant
I'm beginning to see a pattern it apears to be happening every 10 minutes I was not using any services at the time so I don't know if it caused a disconnect.
See Event Log :
12:51:52, 03 Dec. (358181.280000) Device disconnected: Hostname: desktopW8 IP: 192.168.1.72 MAC: a4:.................
12:51:42, 03 Dec. (358171.280000) Device disconnected: Hostname: XWN5001 IP: 192.168.1.73 MAC: a4:2.........................
12:48:14, 03 Dec. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:36342->[31.13.90.1]:443 on ppp3)
12:46:57, 03 Dec. (357886.280000) Device disconnected: Hostname: desktopW8 IP: 192.168.1.72 MAC: a4..............................
12:46:57, 03 Dec. (357886.280000) Device disconnected: Hostname: android-bec62d36ef15c48a IP: 192.168.1.69 MAC: ............................
12:45:07, 03 Dec. (357775.700000) Lease for IP 192.168.1.105 renewed by host 0005CD26BE10 (MAC ..................10). Lease duration: 1440 min
12:45:07, 03 Dec. (357775.700000) Device connected: Hostname: 0005CD26BE10 IP: 192.168.1.105 MAC: .........................:10 Lease time: 1440 min. Link rate: 100.0 Mbps
12:45:07, 03 Dec. (357775.630000) Lease requested
12:42:02, 03 Dec. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:35033->[31.13.90.1]:443 on ppp3)
12:41:42, 03 Dec. (357571.280000) Device disconnected: Hostname: XWN5001 IP: 192.168.1.73 MAC: ......................................- rosmith52Dec 03, 2015Aspirant
Have now added another Powerline xavb5221 and connected a laptop via cable, at 14:02 I was disconnected from the internet connected to the xWN5001. I checked the laptop and could not connect to the internet.
14:07:26, 03 Dec. IN: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [64.233.167.95]:443->[146.90.46.207]:61993 on ppp3) 14:02:58, 03 Dec. (362446.890000) Device disconnected: Hostname: XWN5001 IP: 192.168.1.73 MAC: a4:2b:8c:07:26:e3 13:59:37, 03 Dec. BLOCKED 6 more packets (because of ICMP replay) At 14:11 I disconnected the XWN5001 and all devices now using XAVB5221 then I get
14:15:38, 03 Dec. (363206.900000) Device disconnected: Hostname: XWN5001 IP: 192.168.1.73 MAC: a4:2b:8c:07:26:e3 - rosmith52Dec 03, 2015Aspirant
Been runnng now for over an hour with no disconnects, does this mean the XWN5001 is faulty or is too early to jump to conclusions. The Event log shows
15:12:12, 03 Dec. IN: BLOCK [16] Remote administration (TCP [178.71.80.34]:59209->[146.90.46.207]:22 on ppp3) 15:10:18, 03 Dec. (366487.010000) Device disconnected: Hostname: XWN5001 IP: 192.168.1.73 MAC: a4:2b:8c:07:26:e3 15:10:18, 03 Dec. (366487.000000) Device disconnected: Hostname: W8LAPTOP IP: 192.168.1.64 MAC: 34:17:eb:75:62:7d 15:10:18, 03 Dec. (366487.000000) Device disconnected: Hostname: android-3b7221a611bdf6d3 IP: 192.168.1.71 MAC: f8:e0:79:eb:9c:56 15:10:18, 03 Dec. (366487.000000) Device disconnected: Hostname: android-bec62d36ef15c48a IP: 192.168.1.69 MAC: 30:85:a9:d8:9c:f3 15:10:18, 03 Dec. (366487.000000) Device disconnected: Hostname: 0005CD26BE10 IP: 192.168.1.105 MAC: 00:05:cd:26:be:10 15:10:18, 03 Dec. (366487.000000) Device disconnected: Hostname: android-40195f60849f1f78 IP: 192.168.1.67 MAC: b4:ce:f6:08:ba:49 15:10:17, 03 Dec. BLOCKED 6 more packets (because of Packet invalid in connection) The Xwn5001 has been sitting on my desk for an hour is this just the router releasing the lease?
