gummi
Jul 09, 2015Aspirant
XWNB5201 vs XWNB5221
What is the difference between XWNB5201 and XWNB5221? I noticed a difference in physical dimensions but is there anything else? Trying to decide which one to get.
SamirD
Oct 12, 2015Prodigy
I would forget trying to go wireless if you're using powerline. Just get a powerline to work in an outlet near the television and run a cable--your speeds will be much, much faster this way and netflix will seem like tv. How do I know? Because that's what I did.
We have an FVS318N literally 6 feet away on the other side of a wall. Just for kicks, I connected a powerline to the FVS318N via a cable and then put another powerline by the tv and connected the tv by cable. The results? The internet speed on the television was 6x faster via powerline. I left the powerlines in place and the television wired.
- JeannetOct 12, 2015Tutor
Thanks very much for your response, Samir. I have in the end used a Netgear Wifi Network Extender, and that's working really well. Many thanks for your suggestion, though. All the best, Jeannet :-)
- SamirDOct 12, 2015Prodigy
You're welcome! If speed is every an issue, now you know exactly what to do. ;)
