kha_grejs's avatar
kha_grejs
A6100 - WIFI adapter has to be re-installed after is has been closed down
Hej
I have that problem that every time I start my desktop I have to reinstall my wifi adapter(A6100 - WIFI USB Mini adapter) and IM pissed about it. So any good Ideas to solve my issue is recommended, ths in forward!
  • plemans's avatar
    What device is this connected to?
    Is it running windows and what version?
    What driver version are you using?
    Have you tried installing the stand alone driver and not installing the utility?
    • kha_grejs's avatar
      kha_grejs
      What device is this connected to? desktop Medion Desktop from last year
      Is it running windows and what version? win 10 version 2004
      What driver version are you using? the standalone and I think its the newest one
      Have you tried installing the stand alone driver and not installing the utility? That I do everytime when I start my computer and I have tried to uninstall it also, and then I only install the  STANDALONE version
      • plemans's avatar
        Medion desktop from last year tells us nothing.
        Have you tried it in a different pc/laptop to see if its an issue with your specific pc?
  • michaelkenward's avatar
    michaelkenward
    kha_grejs wrote:
    ... every time I start my desktop I have to reinstall my wifi adapter#
    Why? What error messages, or strange behaviour, do you see that force this on you?
    In other words what symptoms cause you to reinstall every time?
    Why not check this? Seems like an obvious first move.
