Robber
Oct 18, 2016Aspirant
A6100-10000S Windows 10 v1607 IPv6 Issue
I am finally running Windows 10 Anniversary Upgrade, version 1607, build 14393.xxx, with the A6100 Wireless AC Adapter running the latest Netgear driver set, 1.0.0.32. Under version 1511, the adapter performed well with all features showing agreement with status reported by icons and labels in taskbar and in network and sharing center. Homegroup was active with PC status as "private". This is no longer true with W10 V1607.
I did not/do not use Netgear A6100 MPC software to manage under either version.
Now A6100 connects to wireless lan and the internet. I note that my connection is IPv6 protocol at 5MHz when with v1511 it was IPv4 at 2.4MHz. Status confirms internet is connected for both IPv4 and IPv6, Media state is enabled, and SSID is correctly shown. Chrome and Firefox function normally in searches and website usage; I do not use MS browsers. But taskbar's wireless icon is asterisked and lable reads "Not connected - connections are available". Connections Available shows SSID as "secure, no internet". Control Panel Basic Information reports that "You are not connected to any networks", and Change Adapter Settings Network Connections icon shows that Netgear A6100 WiFi Adapter is "Enabled" rather than listing SSID of wireless network connection. Also, "Computer cannot connect to a Homegroup" since status is "public" and cannot be changed to "private".
Norton Security Suite updates just fine, but Windows Update cannot "check for updates because you are not connected to the internet."
Reverting back to W10 v1511 sets everything right again, but that is not what I want to do. This has all appearances that the IPv6 protocol is not properly managed in W10 v1607 but I only speculate. This would indicate a driver issue affects proper network management.
Anyone else seeing this? Any insights would be welcome.
- JamesGLNETGEAR Employee Retired
Hi Robber,
Do you have other Windows 10 wirless computer that works fine with IPv6 after the update? We have to isolate if the issue is only for drivers of the NETGEAR adapter or with the anniversary update of Windows.
JamesGL
Community Team
- RobberAspirant
James,
Thank you for your interest.
No, unfortunately I do not own another wireless PC running Windows 10 Anniversary, 'though wouldn't that have been helpful to us both!
I still have the problem with the system properly recognizing a working internet network connection or the network that it is connected to. I have made some headway in the last days and now believe that it is not only isolated to the IPv6 protocol. I cannot, however, isolate the problem as originating with Windows 10 Anniversary or with the A6100 driver: I disabled the IPv6 radio and primary from my router and achieved internet connection through IPv4 only and obtained the same non-recognition of the connection. Before doing so, I specified Private IPv6 addresses (fd00 etc.) which were not recognized as private. My IPv4 address begins 192.168, is private, but the system thinks it is public.
I have used the Task Manager to investigate the effect of enabling those Services which are "network connection related" but which are not running on the system. I disabled Norton Security Suite (NSS), Windows Firewall (which is under NSS control), and the firewall in my ARRIS SBG6700-AC cable modem/wireless router. I scanned for malware and adware and found nothing. I've run SFC and DISM, reset IP, DNS, and Winsock. I have run all the relevant Trouble Shooters. The Homegroup reports my issue is with the Network. The Network Troubleshooter finds nothing actual but offers to reset my network devices (because I have disabled my on-board wireless for lack of a driver -- that's why I bought the A6100 in the first place); I did reset without resolving the issue. I even tried to load drivers for the A6200 (more recent driver dates) series into the A6100 but they do not load. Please note that the Win 10 1.0.0.32 drivers are identical in byte size and date as the Win 8 drivers; how can this be correct if a new driver was touted as being created for use in Win 10?
I have noted something else unusual with Win10Anniv: there are developer features that I want to enable in the effort to fix my issues such as Device Discovery. This separate issue has sent me down a rabbit hole of bad correction efforts. These require the loading of a package which the system finds but cannot install. Further, it is not listed as an app to add.
Since it has been more that 10 days, I cannot restore Win 10 v1511, but I want to because nearly everything worked properly. I can't update v1607 since October 8th: MS requires that the system be connected to a network to update. MS doesn't have a download site that users can access in the alternative.
While I cannot say for certain that the issue is with the Netgear A6100 Driver, it deserves in-house testing on the basis of this user's anecdotal experience.
- RobberAspirant
James,
