Troubleshooting
716 TopicsA6150
My WiFi stopped working in my 3 year old Dell laptop. My ethernet continues to work. I assumed it was the internal adapter, and purchased an inexpensive but reliable A6150 USB Wireless Adapter to be able to use my laptop in a Wireless environment. (Going camping tomorrow for a week). Now, neither adapter is finding my network connection, which is working because my cell phone picks up the Wireless network at my house. Even after uploading current drivers for both Wireless adapters, when I unplug the ethernet cable, the Wireless network is not showing up. I have run through Windows diagnostics to no solution. I also disabled the old adapter and tried the new one, but to no avail. Can anyone suggest the next troubleshooting step prior to me taking it to a computer repair center? All helpful suggestions are appreciated. I am running Windows 10. Thanks, Danny287Views0likes1CommentNetgear A8000 getting 50 Mb/s in same spot my phone gets 490 Mb/s (firmware is up-to-date)
I just moved into an apartment. In my folk's house, my netgear A8000 adapter was pulling about 160-350 Mb/s, depending on who else was using the wifi. Now, I'm the only person using the wifi, and my phone, sitting underneath the netgear adapter, runs a test speed of 450-490 Mb/s, but my PC only pulls 30-50Mb/s on a speed test. I have updated the firmware. I have made sure it was in a USB 3.0 slot (even though I should be getting way more speed out of a 2.0). My modem is a Calix GigaSpire Blast, model u6x GS4227. My OS is Windows 10. It's dumb, but I've gotten used to downloads taking 10-15 minutes rather than 3-5 hours. I can't find any advice that doesn't involve updating firmware. Help?1.5KViews0likes6CommentsConnection Issues with Wifi USB Adapter Model A7000
Hi, I have two "WiFi USB 3.0 AC1900 (A7000)" which I have been using for a long time on two different PCs with Win11. Before "Win11" latest update, my Wi-Fi speed was about 650mbs in download, and 310mbs in upload. Besides, "Netger Genie" was working correctly detecting automatically my Wi-Fi. After Win11 update of 11/22/2024, the two WiFi Adapters USB 3.0 AC1900 (A7000) stopped working properly, and Netger Genie started showing a red flag in the notification area (i.e. it couldn't manage any more the adapter, on both computers). I have tried everything possible, even reinstalling the OS and Netgear Genie, but up to now with my adapters I only reach a maximum of 330mbs in download. Is there something more specific I can try? Is there any chance to download a Win11 driver specific for WiFi USB 3.0 AC1900 (A7000)? Many thanks in advance for your help. M #WiFiUSB3.0AC1900(A7000) #Win11 #NetgearGenie3.4KViews0likes12CommentsA6100 drivers crash without error during install section
When I open both the adapter and standalone EXEs they both crash once the preparing to install bar reaches 60% every time I open them they then proceed to leave a ghost background process behind in my task manager labeled “InstallShield (R) 64-bit Setup Engine” one will appear in my TM per attempt at installation and won’t close on there own without me closing them using TM I can recreate this issue on video if needed it seems to me the driver installer really doesn’t want to open net gear genie it doesn’t even get to that screen any help would be appreciated1.7KViews0likes5CommentsNetgear A6100 Wifi adpaters dropping out
I have a client that has approx 12 desktops all running Windows 10 and connected to their Wireless via Netgear AC600 USB adapters. They report and I have experienced them devices frequently dropping the connection, with a number of events in the event log each time the network connectivity is lost. I have tried: reinstalling the drivers from NG,(V 1030.25.701.2017) checked for firmware updates, uninstalled the drivers to see if Windows native drives help but nothing has so far worked. tried different driver versions to see if there are specifics to each machine Are there any known issues with these? Given the number of these adapters the client owns and the fact all are dropping connectivity at different times and duration's suggests there are.1.1KViews0likes2CommentsA7000 USB Adaptor cannot see or detect any network SSID after SLEEP Mode
I was able to install the Netgear Genie and drivers for the A7000 on my Toshiba i7 laptop. My Toshiba is an older but reliable laptop and I wanted faster connectivity. The initial installation went find without a problem and I finally experienced high speed internet at 900+ Mbps. However, when I put my laptop to sleep (and me sleeping of course), the A7000 adapter seems to be unavailable when I get out of sleep mode. In Netgear Genie, there would be ZERO/nada/zilch SSIDs. I would normally be able to see all my 2.4 G and 5G SSIDs and my neighbors SSIDs as well. I have followed suggestions in other posts - like unchecking the power management options. In theory, if I run Netgear Genie, the software should "awaken" the A7000 adapter, but it does not. Any suggestions, please. My setup: A7000 Nighthawk AC1900 Dual Band Wifi USB 3.0 Adaptor | Toshiba P775-S7320 i7 laptop running Windows 7. | Cox GigaBlast Panoramic Router4.8KViews0likes3CommentsAC19000 USB Adapter constantly getting high ping spikes
I have a AC1900 USB adapter for 2 months now and it has been acting up for the last two weeks. Started out by dropping connection at random times, but I fix that with CMD. Now it shows I getting 200 mbps and it does not feel like that. I will be playing a MP match in video games and my ping will go from 40 to 300 then 90 and back to 40. It is pretty hard to play with a stutter in the WiFi. I tried using my old tp link adapter and it works fine. Is there any fix because it's very annoying paying $90 for a high speed adapter that is being outperformed by a $10 adapter.2.5KViews0likes5Comments5ghz network not connecting at boot NETGEAR AXE3000 A8000
I am using a router with both a 2.4 GHz and 5GHz connection. Since purchasing and using the NETGEAR AXE3000 (A8000) series adaptor, I have noticed that on some system startups, the Netgear adaptor will not be able to locate and connect automatically to the 5GHz network. When I open my available networks, the 2.4 GHz network is always available, but the 5GHz is not in the list of possible connections. I am able to toggle my Wifi connection on and off, and eventually pick up the 5GHz network, and after that there is no problem or dropped connection. The router is in an adjacent room, and the signal for both bands is strong. So far I am strapped for ideas, as searches for this particular issue have come up empty. I have tried setting the adapter's preferred band to 5GHz, and made sure that the latest driver is installed through the Devices panel. System: Windows 10 v10.0.19045 Netgear Driver Version: 1.0.0.1082.4KViews0likes3CommentsA6210 Constant Disconnecting
Netgear A6210 Wifi Adapter in USB 3.0 port Windows 10 Pro version 21H2 Specs too good to be relevant whatsoever Constant disconnecting (USB sound) and disconnecting when attempting speedtest I have done all the fixes available online... Power settings, making sure the port is always on 3.0, changing usb ports, updating, uninstalling, and reinstalling firmwares, uninstalling and reinstalling drivers, disabling and getting rid of NetgearUSBSw in services, etc etc. If you can think or find a fix online, I have probably already done it. Please give me some help before I cave and go find another brand and option. Will be moving to pci-e wifi and a new brand if this isnt sorted. I have had this problem for the 2 years I have had this adapter and I am tired of it. Thanks in advance, Caine.4KViews0likes10CommentsNetgear AC1200 USB is not detecting my wifi network
Yesterday my AC1200 USB which was has been working fine for several months stoped connecting to my wifi abruptly. When I try to connect to my wifi network Windows says no networks are detected. I still have wifi on my phone and other devices though. In device manager, the AC1200 appears under the “Network adapters” section and the device status is “This device is working properly” so I think it’s connecting to my PC fine. I tired restarting my PC, uninstalling and reinstalling drivers, trying different USB ports, and a few other methods I found online but none of them worked. Any ideas on how I could go about fixing this are appreciated. Thanks.2.2KViews0likes4Comments
