Kodithebree's avatar
Kodithebree
Netgear A8000 getting 50 Mb/s in same spot my phone gets 490 Mb/s (firmware is up-to-date)
I just moved into an apartment. In my folk's house, my netgear A8000 adapter was pulling about 160-350 Mb/s, depending on who else was using the wifi. Now, I'm the only person using the wifi, and my phone, sitting underneath the netgear adapter, runs a test speed of 450-490 Mb/s, but my PC only pulls 30-50Mb/s on a speed test.
I have updated the firmware. I have made sure it was in a USB 3.0 slot (even though I should be getting way more speed out of a 2.0).
My modem is a Calix GigaSpire Blast, model u6x GS4227.
My OS is Windows 10.
It's dumb, but I've gotten used to downloads taking 10-15 minutes rather than 3-5 hours. I can't find any advice that doesn't involve updating firmware.
Help?
  • plemans's avatar
    are you connecting to the 2.4ghz or the 5gh?
      • plemans's avatar
        what happens if you change the channel the 5ghz is on?
        What link speed does you pc show?
