Kodithebree
Jan 13, 2025Aspirant
Netgear A8000 getting 50 Mb/s in same spot my phone gets 490 Mb/s (firmware is up-to-date)
I just moved into an apartment. In my folk's house, my netgear A8000 adapter was pulling about 160-350 Mb/s, depending on who else was using the wifi. Now, I'm the only person using the wifi, and my ...
Jan 13, 2025Guru - Experienced User
are you connecting to the 2.4ghz or the 5gh?
- KodithebreeJan 13, 2025Aspirant
I am connected to the 5 GHz
- plemansJan 14, 2025Guru - Experienced User
what happens if you change the channel the 5ghz is on?
What link speed does you pc show?
- KodithebreeJan 14, 2025Aspirant
I can't find any way to change the channel. (All I could find was instructions for changing it on netgear routers, but I don't have a netgear router)
The network channel is 100, and it says the channel speed is 1201/1201 (Mbps)
