Kodithebree
Jan 13, 2025Aspirant
Netgear A8000 getting 50 Mb/s in same spot my phone gets 490 Mb/s (firmware is up-to-date)
I just moved into an apartment. In my folk's house, my netgear A8000 adapter was pulling about 160-350 Mb/s, depending on who else was using the wifi. Now, I'm the only person using the wifi, and my ...
Kodithebree
I am connected to the 5 GHz
Jan 14, 2025Guru - Experienced User
what happens if you change the channel the 5ghz is on?
What link speed does you pc show?
- KodithebreeJan 14, 2025Aspirant
I can't find any way to change the channel. (All I could find was instructions for changing it on netgear routers, but I don't have a netgear router)
The network channel is 100, and it says the channel speed is 1201/1201 (Mbps)
- michaelkenwardJan 15, 2025Guru - Experienced User
The broadcast channels are in the hands of your router. The adapter just looks for what is there and connects to that.
Any router should have instructions on how to change the wifi output. Find its manual and read that.
Just another user with time on their hands.
