crispin
Feb 12, 2015Novice
A6100 Blue Screen SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Hi - Hope you can help!
OS Win 8.1
A6100 Software Version 1.0.0.17
Installed the software, plugged in the adapter at the software prompt, then the system bluescreens immediately:
Address A6100.sys+168e6f
Bug Check String SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code 0x1000007e
Parameter 1 ffffffff`c0000005
Parameter 2 00000000`00000000
Parameter 3 ffffd001`4cdace28
Parameter 4 ffffd001`4cdac630
1 Reply
- BuckinghamshireAspirantAs fast as possible after boot go to device manager and uninstall the driver. Then install the driver via the installation disc that came with it.
Now connect to the Internet but not via the Genie, but the normal windows way. This worked for me when I got your problem.
