mrcpuhead
Apr 24, 2022Aspirant
A6100 Cannot Find Nighthawk RAX48 network!
I find this problem extremely ironic. I have a known good NETGEAR A6100 USB wifi adapter on a Windows 10 computer. I say known good based on the fact that it works with at least two networks: my work...
Apr 25, 2022Guru - Experienced User
I know this sounds stupid but you talked about the adapter able to pickup other networks. But are other devices able to see the RAX's broadcast?
mrcpuhead
Apr 25, 2022Aspirant
Yes, every other device in my home sees the router and works fine. This is, again, cruel irony that the ONLY Netgear device in my home is the one that doesn't work with a Netgear router!
