cummingsjp
Mar 12, 2017Aspirant
A6100 Genie not starting
When I try to start the A6100 Genie, I get a quick flash but then nothing. I can't see if the A6100 is working or not, although I suspect that it isn't.
- Mar 16, 2017
Hi cummingsjp,
Is the adapter now working?
JamesGL
Mar 13, 2017NETGEAR Employee Retired
Hi cummingsjp,
1. Are you trying to install the adapter?
2. What driver version you are using?
- cummingsjpMar 14, 2017Aspirant
I'm sorry. I pulled a real bone-headed move. I mistook my wireless mouse adapter for the A6100.
SMH
Jim
- JamesGLMar 16, 2017NETGEAR Employee Retired
Hi cummingsjp,
- cummingsjpMar 17, 2017Aspirant
Yes it is, thank you.
It really helps when the adapter is actually plugged into the computer. . . . .
Thank you again and I'm sorry to have wasted your time. . . .
Jim
