mluna20
Jul 09, 2014Tutor
A6100 keeps disconnecting
Running Windows 8.1. Disabled USB selective suspend. Did not help Any suggestions?
jmizoguchi
Jul 09, 2014Virtuoso
Make sure you are not using USB ports with other devices like ext USB HD etc.
USB port are paired as one so watch where the USB is shared with. If PC active and used the should not disconnect you unless issues are other interference issues
