sli7de
Jul 29, 2016Aspirant
A6100 Loading drivers
I am having issues getting the drivers to load in Windows Server 2016 TP 5.. The drivers I have did load fine in TP3 and TP4 but not TP5. If I run the setup, it says that it can not find the adapte...
- Aug 01, 2016
This is what I had to do, Microsoft issue!!
[ Cumulative Update for Windows Server 2016 Technical Preview 5 for x64-based Systems (KB3172982) ]
http://download.windowsupdate.com/d/msdownload/update/software/crup/2016/06/windows10.0-kb3172982-x64_7c13dfeba2f9853fa4ff6e5fb032cee8b344accb.cab
dism /online /add-package /packagepath:D:\windows10.0-kb3172982-x64_7c13dfeba2f9853fa4ff6e5fb032cee8b344accb.cab /LogPath:AddPackage.log /NoRestartDism /online /enable-feature /featurename:WirelessNetworking /All /Source:D:\WinSRV2016\sources\SxS
sc config WlanSvc start=auto
sc start WlanSvcit can connect via settings
JamesGL
Jul 31, 2016NETGEAR Employee Retired
Hi Sli7de,
Please check the system requirements of the adapter under Tech Specs. Your OS may not be supported.
https://www.netgear.com/home/products/networking/wifi-adapters/A6100.aspx#tab-techspecs
JamesGL
Community Team
- sli7deAug 01, 2016Aspirant
