viscount45
Apr 28, 2015Aspirant
A6100 on Windows 10
I tried installing in Windows 8 Compatibility Mode but the PC cannot detect the device. Anyone know of a temporary fix until final release of Win10 and drivers are made available? Thanks, all.
RH
Jul 29, 2015Tutor
1. In device manager, click on the 6100 and choose update driver, browse my computer, let me choose which drivers, and uncheck show compatible drivers
2. Select Realtek Semiconducter Corp (use the 2nd one down on the list - there are two in a row)
3.On the right side select Realtek 8812AU Wireless LAN 802.11 ac USB NIC Version 1027.4.1120.2014 (use the second one down on the list again with the driver date of 02/17/2015)
4. Ignore the warning message and install it anyway
5. Should Work for Windows 10 Now!
- SpizardJul 31, 2015Aspirant
Awesome! This seem to work for me!
Thanks!
- smsunderAug 04, 2015Guide
Thanks for recommendation...worked for me after upgrading to Windows 10 today!
- Aftershock5167Aug 05, 2015Aspirant
Wow ....i dont know how on earth out of all those drivers in there you figured out that this one works!!!! you are a absolute Genius and please know that i am #1 grateful as heck for this and #2 completely blown away by your super computer brains AwesomeNess!
- BearyApple77Aug 08, 2015Aspirant
I have checked my desktop and Realtek 8812AU Wireless LAN 802.11 ac USB NIC Version 1027.4.1120.2014 isn't an option for me. I have Win7 now, but I did have Win10. I had to uninstall after A6100 Adapter wouldn't work! Anyone that might have another option would be great!
- DarrenMAug 14, 2015Sr. NETGEAR Moderator
Hello everyone
We are looking into the issues with the A6100 and upgrading to win 10 we have another thread with some information on how to get the adapter working and also if you are having issues we are collecting information from the community so we can fix those issues so please look at this thread.
DarrenM
- zipdriveNov 18, 2015Tutor
It should be in the list under that name. If you go back to 10... try doing what the guy said that posted...it's important that when you pick the driver that you are looking at a double listbox... manufacturer on the left and actual version on the right.
- mrlerchAug 18, 2015Aspirant
So I did what you said, and it is now recognizing the A6100. I am also connected to the local network, and it says that I am connected to the internet, however none of my browsers can bring up a web page. At first I thought that it may be a firewall issue, so I disabled it, but that didn't work either. So it shows as fully connected and working, however I can't get to the internet. Please advise.
Thanks,
MrLerch
- DarrenMAug 18, 2015Sr. NETGEAR Moderator
Hello Mrlerch
First try going to your command prompt CMD and then type ipconfig to see if you are getting a ip address next if you are type ping www.google.com into the command prompt and see if you are able to ping out to google. Let me know what you get
Pinging
http://kb.netgear.com/app/answers/detail/a_id/989
Ipconfig
http://kb.netgear.com/app/answers/detail/a_id/23664
DarrenM
- RHAug 18, 2015Tutor
Mrlerch
You prolly have some a6100 program running in the background somewhere or otherwise windows10 is reverting back to the old driver or another configuration all on its own. Check to see and if so uninstall it. Also, in device manager uninstall a6100 driver, unplug the usb nic, then plug it back in and follow instructions in my previous post. Should work fine after that.
RH
Amazing! It's working. You were right. I had the Genie software driver installed. I uninstalled it and then unplugged the dongle, then replugged it and then installed the driver you recommended, and ---- YES!!!! Local area and Internet working! Super. Thank you!
Shame on Netgear though for not updating their drivers!
Thanks,
MrLerch
- MountainMan500Aug 22, 2015Aspirant
Worked like a champ and saved me a great deal of time!
- pratyushpksSep 03, 2015Initiate
Hi RH,
This is working. I would add something more here for help to others if they get confused. First remove the Netgear Genie or standalone driver which you have installed earlier.
Once that done use the method given by RH which is
For a check, when you see the device back in Device Manager , it should bear the name of Realtek adaptor and not Netgear A6100. To connect to network you can go the Network setting in Win10, scroll down to the newly installed device name, and then select the 5GHZ wifi ssid.
Cheers,
Pratyush
- 2012WingdadokSep 26, 2015Aspirant
Fortunately this "workaround" was also successful for me, at this time. We'll see how long it will last, It truly is disappointing to know Netgear hasn't stepped up to the plate to upgrade the drivers for it's products. I'm certain there are thousands of their products still on the shelves and this just seems ludicrious! Not everyone has the technical skills to apply this kind of a fix and will wind up having to PAY $omeone to fix it for them...Good grief Charlie Brown!
- JamesGLSep 29, 2015NETGEAR Employee Retired
Hi All,
There is a KB article for A6210 which is same with A6100 workaround.
JamesGL
Community Team
- postet17Sep 04, 2015Aspirant
:manhappy: OMG.. Thank you so much for this posting. I have spent days trying to get my USB wifi adapter to work again after updating to Windows 10. Thank you so much you are a true life saver.
- RobSimpleSep 18, 2015Aspirant
OMG i thought i was out of service until i saw this work around.. Thank you! THIS WORKS!
Thanks a bunch for the workaround. I was in Office Depot looking this up on my phone and was reading the first few posts on this and was about to just put it back. Read the workaround and went ahead and bought it. I had purcahsed some Etechcity brand on Amazon that did not work... worked great for Win 7 .. still needed them so kept them. I wonder if there is a generic driver that would have worked for them? Oh well.. I'm good now. Shame on M$ and the stupid vendors for not getting on the same page with this b/c Netgear isn't the only one. It seems like NO ONE has drivers for 10.
