viscount45
Apr 28, 2015Aspirant
A6100 on Windows 10
I tried installing in Windows 8 Compatibility Mode but the PC cannot detect the device. Anyone know of a temporary fix until final release of Win10 and drivers are made available? Thanks, all.
RH
Jul 29, 2015Tutor
1. In device manager, click on the 6100 and choose update driver, browse my computer, let me choose which drivers, and uncheck show compatible drivers
2. Select Realtek Semiconducter Corp (use the 2nd one down on the list - there are two in a row)
3.On the right side select Realtek 8812AU Wireless LAN 802.11 ac USB NIC Version 1027.4.1120.2014 (use the second one down on the list again with the driver date of 02/17/2015)
4. Ignore the warning message and install it anyway
5. Should Work for Windows 10 Now!
smsunder
Aug 04, 2015Guide
Thanks for recommendation...worked for me after upgrading to Windows 10 today!
