viscount45
Apr 28, 2015Aspirant
A6100 on Windows 10
I tried installing in Windows 8 Compatibility Mode but the PC cannot detect the device. Anyone know of a temporary fix until final release of Win10 and drivers are made available? Thanks, all.
RH
Jul 29, 2015Tutor
1. In device manager, click on the 6100 and choose update driver, browse my computer, let me choose which drivers, and uncheck show compatible drivers
2. Select Realtek Semiconducter Corp (use the 2nd one down on the list - there are two in a row)
3.On the right side select Realtek 8812AU Wireless LAN 802.11 ac USB NIC Version 1027.4.1120.2014 (use the second one down on the list again with the driver date of 02/17/2015)
4. Ignore the warning message and install it anyway
5. Should Work for Windows 10 Now!
mrlerch
Aug 18, 2015Aspirant
So I did what you said, and it is now recognizing the A6100. I am also connected to the local network, and it says that I am connected to the internet, however none of my browsers can bring up a web page. At first I thought that it may be a firewall issue, so I disabled it, but that didn't work either. So it shows as fully connected and working, however I can't get to the internet. Please advise.
Thanks,
MrLerch
- DarrenMAug 18, 2015Sr. NETGEAR Moderator
Hello Mrlerch
First try going to your command prompt CMD and then type ipconfig to see if you are getting a ip address next if you are type ping www.google.com into the command prompt and see if you are able to ping out to google. Let me know what you get
Pinging
http://kb.netgear.com/app/answers/detail/a_id/989
Ipconfig
http://kb.netgear.com/app/answers/detail/a_id/23664
DarrenM
- RHAug 18, 2015Tutor
Mrlerch
You prolly have some a6100 program running in the background somewhere or otherwise windows10 is reverting back to the old driver or another configuration all on its own. Check to see and if so uninstall it. Also, in device manager uninstall a6100 driver, unplug the usb nic, then plug it back in and follow instructions in my previous post. Should work fine after that.
RH
- mrlerchAug 18, 2015Aspirant
Amazing! It's working. You were right. I had the Genie software driver installed. I uninstalled it and then unplugged the dongle, then replugged it and then installed the driver you recommended, and ---- YES!!!! Local area and Internet working! Super. Thank you!
Shame on Netgear though for not updating their drivers!
Thanks,
MrLerch
